Results 1 to 4 of 4
    Mar 2017
    Default 38906012HA-SG Tuning
    I'm tuning a Skoda Octavia 90HP ALH 2005 VEP (EDC15VM+)
    I found the smoke limiter on address 4D492 but it doesn't work. While live testing with Vag-com it reported it's still limited by Airflow with 38mg. while it should read 45mg. I tried changing the coding to automatic to see if I got the wrong map but still only reading 38mg. Measured airflow being well above 850mg/str everytime.
    What could be the problem here? I don't seem to find any more smoke limit maps than that two (4D492 and 6D492).
    Jun 2018
    Bulgariq
    Quote Originally Posted by Cotulla View Post
    First you lost a lot of cards and at least you didn't touch the voltage of the pump
    Jun 2018
    Bulgariq
    Default edc15
    pass- PM
    Give a repot and thank you and you'll get a password
    126HP 306NM
  4. The Following User Says Thank You to naskochipa For This Useful Post:
    Cotulla (14th October, 2019)
    Mar 2017
    Quote Originally Posted by naskochipa View Post
    Why did I lose a lot of cards, can you explain? Pump voltage needs no change as I'm not requesting more than 51mg.
    Isn't 300+ NM way too much for the gearbox, I've read that one should not push for more than 270NM as the gearbox won't handle it?
    I pressed thank you, what do you mean with report?
