Results 1 to 15 of 17
    May 2014
    Default MINI COOPER CAS 3 and DME Sync
    Hello ,
    how do i marry DME to CAS 3 to start this mini cooper
    i have attached images of dme and cas
    thanks in advance .
    May 2017
    Read CAS ISN put in DME.
  3. The Following 2 Users Say Thank You to Lambda1 For This Useful Post:
    INFINITY13 (18th October, 2019), narkeleptk (19th October, 2019)
    May 2014
    Quote Originally Posted by Lambda1 View Post
    Thanks Lamda1 ,
    i can read both ISN from CAS ,and i can read DME dump as well
    how do i put CAS ISN into DME and will the car start afterwards or do i need another software to
    finish up ?
    Europe
    Car starts when ISN matches 100%. It would be nice to program it to the car (VIN, correct tune, clear adaptation and taught versions) but the car will start anyway.
    May 2017
    Put both here, files from cas and dme.
    May 2014
    Here you are bro both CAS and DME
    I read cas and got ISN 73 84
    but dont know how to put in DME
    Thanka in advance
    May 2014
    Hello ,
    i am still finding solution to my problem .
    can someone offer hands to syncro cas and dme
    thanks in advance
    Aug 2018
    Eastern Europe
    As I know cas 3 is ews4 system and there is 16 bytes Sekret Key to synch CAS with DME.
  10. #9
    Europe
    Certainly this car uses long ISN. I don't know how to find it in the ECU dump.
    Do you have the CAS that came with the ECU?
  11. #10
    May 2014
    Quote Originally Posted by tomvleeuwen View Post
    No i dont have the CAS
    I bought the ECU separately
  12. #11
    Feb 2019
    Read the DME ISN and write it to CAS. This is the easiest.
  13. #12
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Here is a complete set with Ktag Full ECU backup and CAS3 + and ISN
    One of the two ISN in text file is the right one but i forgot which one is the real one.
    write full ecu dump to your ecu and write cas eprom and flash to your cas3 make key with tango using one of the ISN provided and start car
    Pass in PM
  14. The Following 2 Users Say Thank You to koolstuff For This Useful Post:
    INFINITY13 (22nd October, 2019), tomvleeuwen (20th October, 2019)
  15. #13
    Apr 2016
    i can make synchro
  16. #14
    Europe
    Quote Originally Posted by koolstuff View Post
    Pass in PM
    Full backup with known ISN, nice idea! But why not modify the original CAS with this known ISN, so that the original keys still work?
  17. #15
    May 2014
    Pass in PM
    Thanks so much bro ,
    But that means i have to write new key to CAS3
    using your file .
    let me know if i am correct so i can go for new key and write .
    thanks in advance
