Results 1 to 9 of 9
    Sep 2019
    Ipswich, Suffolk
    Default Bosch EDC15VM+ EGR Removal
    i fitted EGR blank plates to the Audi today. It has a EDC15VM+ ecu. Downloaded file with my kess clone. Can I turn EGR off using EDC suite or do I need to use Titanium or WinOLS?
    Do these work same as EDC15p?
    Jun 2018
    Bulgariq
    Quote Originally Posted by henson12345 View Post
    Post your file
    Post your filePost your file
    Sep 2019
    Ipswich, Suffolk
    Hi, will need to post tomorrow as at work now.
    is it same as 15P where you raise HEX to highest level and that’s it?
    Quote Originally Posted by naskochipa View Post
    Post your file
    Sep 2019
    Ipswich, Suffolk
    How can I adjust this one myself please?
    Apr 2017
    Croatia
    You can easily fill values with max value on egr map, use vagsuite tool. Or use ecm titanium and look for phase of injection, also fill whole map with max value.
    Sep 2019
    Ipswich, Suffolk
    Thank you Sir! As I have blanked off EGR due to it being stuck, as opposed to just mapping it out to leave it closed, will this sort any error codes that may come up?
    Quote Originally Posted by antimon95 View Post
    Sep 2019
    Ipswich, Suffolk
    So increased all the EGR map values to max and I'm getting a couple of EGR related fault codes How do I map these out??
    DiegoStud's Avatar
    Aug 2019
    arwMEAB0KL, arwMEAB1KL- 2 maps both 20x1 not far after EGR base map.
    They are hysteresis maps for activation/deactivation of EGR function depending on injected fuel quantity. Axis is RPM and map is IQ. Set IQ to zero in both and leave the EGR map alone
    Apr 2017
    Croatia
    Increased to maximum means only fresh air coming to cylinder on whole map. Did you remove fault codes with some diagnostic tool?
