Results 1 to 9 of 9
    sasy90's Avatar
    Italy
    Default Smart 450 Key problem
    Hi to all ,
    i've this car in my workshop with SAM 5WK45090 0011868V009 with 9S12DG256 2K79X . On dashboard i see key blinking and "------" on km .
    In ecu i have this dtc :
    P2010 - No CAN comunication with SAM
    P2035 - Problem on automatic gearbox
    I've done virgin SAM 450 with IUD but now DAS can not Initial coding.
    When I do key learning, remote control working ok , but i have foever key blininkg and motor not crank....
    Someone can check for me flash and e2p of SAM if are corrupted?
    Thanks in advance
    Gdansk Poland
    smart 450 have no SAM only ZEE. Immo work by remote- like very old renault, Are You 100% thats 450 ?? I have ------- on dash after zee and ecu change when vin in dash is wrong
    sasy90's Avatar
    Italy
    yes 450...with 9s12...i posted e2p and flash
    sasy90's Avatar
    Italy
    nobody have experience with this car?
    Gdansk Poland
    Remote work??
    sasy90's Avatar
    Italy
    yes...after key maching... I' ve a question, i connect used ecu (with same number) on dash blink fuel gauge full and water temp full with one line and i can not comunicate with ecu...why?i see on forum that i connect ecu and coding key and car start...is correct?
    sasy90's Avatar
    Italy
    Someone can help me??
    Gdansk Poland
    new-used ecu + key sync and must start. When i have broken ecu temp blinking and car dont start. Sometimes after key sync i must disconnect battery for few sec. (central work ok immo locked)
  9. The Following User Says Thank You to adiagnostyka For This Useful Post:
    sasy90 (17th October, 2019)
  10. #9
    snatchme's Avatar
    Dec 2010
    Dutchie
    I know its an old topic, but just for information... if there is no communication with the ECU and if it's a 450 with ZEE (600cc) and fusebox under the seat. check the fusebox under the seat on corrosion and do a good check.. i noticed the corrosion on the second check, first check i missed it. 2 of the 4 fuses where corroded. but because the corrosion is grey it you will easy over look it.
