Test and report...
hi guys
got a amarok cluster is dead after someone tried to do km. van still starts but nothing works. got a second hand clock but the original clock has 24c32 on and the second hand clock i bought has a 24c64 on is there someone who can make the 24c64 file work or swap immo data from the 32 because the 32 starts but nothing works on the cluster. where the clock with the 64 everything works but its not the original clock from the car
Test and report...
nonstarterautos (15th October, 2019)
Thanks will test and report in the morning
Hi still says immobilizer error. No start just start and cut out
What interface you have? Export immo block from old cluster.
do you mean programmers
Yes, tool which read cluster, or you have disassembled it?
nonstarterautos (16th October, 2019)
Disassembled it and read with xprog and put files here. The original cluster came dead to me.. I must just get it alive and the fuel gauge working but if I plug the new cluster in everything works so i just need to transfer immo data or fix file of old clock
These clusters have crypted immo section in eeprom (each cluster with individual key), to swap immo you need AVDI,SMOK or Carprog.
Your inbox is full 👊
