Results 1 to 11 of 11
    bursuc's Avatar
    Oct 2011
    inside MCU
    Default W238 - 2018 - no crank after crash
    Hi all DK friends
    I have a situation here. Car is Mercedes E300 petrol 2018 w238
    Auction buy. Do the diagnostic on the car, i enable the starting after crash on engine ecu and even did scn coding on engine ecu because starter motor did not actuate even after.
    I check "drive authorizition " in all ecu"s and did a FBS 4 TEST along with the key test. All is ok.
    I test starter motor terminal on actual values on engine ecu and is switchin on and off when i press brake pedal and start button.
    Both of starter relay wires are going straight into ecu ( MED 17.2.2 )
    If i activate starter motor relay manually in same time somebody is pressing starting button, car start for 4 seconds and switching off....
    Ocassioanly i get this fault in engine ecu
    P051200 START RELEASE FAULTY
    I lock/unlock the car with remote key and this fault code sometimes goes off but still not starting
    I put some pictures with positive relay box or whatever it is. On the side with the battery i have +12 but the other side i dont have.
    There is a plug with 3 pins ( only 2 are used - gnd terminal 50 ) data pin is unused. Before i put termina 50 to positive starter motor was working when activating relay but no is onli clicking ( only starter motor coil ) i had to take big cable from this fuse/relay box and attach it to a + 12 positive and now is cranking again but still not starting
    I think i must be burn it ... but problem is still at square 1
    Any ideeas would be very appreciated!
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
    Meat-Head's Avatar
    Is there anything in srs for crash data
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    bursuc (15th October, 2019)
    bursuc's Avatar
    Oct 2011
    inside MCU
    Yes. SRS is full of crash data . and in actual values , CRASH is detected. Prior 2018 - i did not have to do anything in SRS and cars were starting .... this is 2018 and it looks to me something has been added in order to make it harder to start it
    Also - front bumer is missing totally along with RADAR module. there is no RADAR module on the car
    Meat-Head's Avatar
    Ok, not sure on model we had some Mercedes in for a towbar. In the trunk
    RIGHT in the corner rear right was a small battery
    if you put your jumper cables in, would hit it, have a look see if has flat second battery
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    bursuc's Avatar
    Oct 2011
    inside MCU
    I also did SCN on engine ecu? Do i need to do on airbag ecu aswell?
    Regards to the second battery i could not fiind one in the boot
    BR
  8. #6
    Meat-Head's Avatar
    No idea then. If your in UK I got pished off with a Mercedes, no answer with
    uk hq, rung the breakdown line to moan, didnt help, but got great load of info
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
    bursuc (17th October, 2019)
  10. #7
    Feb 2016
    Hello
    I have solution i can repair this
  11. #8
    Meat-Head's Avatar
    Quote Originally Posted by pavlo4111 View Post
    Hello
    Yeah its xmas day, spill the beans
  12. #9
    Hello
    I can help you
  13. #10
    Oct 2019
    Did you get sorted? Is the car auto ?
  14. #11
    Dec 2019
    Quote Originally Posted by nae257092 View Post
    Hello
    I can help you
    hi nae I got same problem, can you help me please, pm me
