Results 1 to 8 of 8
    Jun 2017
    Pretoria, South Africa
    Default Toyota Hilux c66 tssop
    Good day
    I have big problem with hilux mileage gd6 2018
    I read 93c66 tssop and saved data did the correctiob and when i want to solder the chip flew in the air and is lost now....
    You think it is possible to modify sop8 eeprom to work
    I have already tried to modify but no mileage is showing
    Any help will be much appreciated
    Thank you
    Sent from my MAR-LX1M using Tapatalk
  2. The Following User Says Thank You to BraLaas For This Useful Post:
    Nicolas9 (16th October, 2019)
  3. #2
    Nicolas9's Avatar
    Feb 2017
    Aruba
    haha nice try, but you need new eeprom. or find original (maybe use vacuum cleaner with a new bag)
  4. The Following User Says Thank You to Nicolas9 For This Useful Post:
    BraLaas (16th October, 2019)
  5. #3
    Jun 2017
    Quote Originally Posted by Nicolas9 View Post
    I will try that haha i have remove pin 7 from eeprom and then mileage show 0 km
  6. #4
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    8-Pin SOIC to DIP Adapter use a 93c66 soic chip and solder onto the adapter and adapter pins to pcv where the msop 93c66 chip was before it took off ...
    Works for Avanza as well
    'If I helped, please click Thanks +Reputation.. !'
    SEAT.'s Avatar
    CAPE TOWN
    Try using thinner wire
  8. The Following User Says Thank You to SEAT. For This Useful Post:
    rtbdiagnostic (31st October, 2019)
  9. #6
    Jun 2017
    I have sorted this out
    I will make an post about how i did it so next time when someone is in trouble they can use my post to sort out the problem with old hilux eeprom
  10. #7
    Jun 2017
  11. #8
    Aug 2020
    Quote Originally Posted by BraLaas View Post
    How did you solved this?
