Thread: Checksum
    diagtech2000's Avatar
    Jul 2013
    North of England
    Default Checksum
    hi
    i used ADS DPF Remover to remove DPF from a file,
    it then says DPF removed, PLEASE DONT FORGET FIXED THE CHECKSUM,
    does this mean that the SW has corrected/Fixed the Checksum for me o do i need to use another program to fix/correct the CS?
    Please hit thanks if this helped you!
    Aug 2019
    España
    Default Checksum
    Hi, here you have
    First thanks and add to rep for pass
  3. The Following User Says Thank You to SabeFacu For This Useful Post:
    diagtech2000 (16th October, 2019)
    Jul 2013
    North of England
    Default Checksum
    cheers i don’t actually need this file right now but thanks a lot anyway,
    im just trying to learn/get my head round the sw required to do egr/dpf/dtc off myself
    would my kess of corrected the chks if id of just tried to write the file before you corrected cs?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by diagtech2000 View Post
    here answer for free...
    no rep and no thanks...
    yes, before kess start to write...
    ksuite will autom. calculate and correct cheksum...
  6. The Following User Says Thank You to figani For This Useful Post:
    diagtech2000 (18th October, 2019)
    Jun 2018
    Bulgariq
    hi
    These programs are bad, use WinOls If you want to make sure everything is OK, these programs should rub everything
  8. The Following User Says Thank You to naskochipa For This Useful Post:
  9. #6
    Jul 2013
    North of England
    ok ill have to do some serious reading/learning/practising after looking at a few videos
