Good Luck!
Good Luck!
Wilberg93 (22nd October, 2019)
hey bud does not work doesnt read miles on my carprog
still using Carprog to edit mileage?......file is good mate
I wrote the dump with carprog. Wrote fine but the mileage doesn’t show either on carprog or jprog I have both
Someone please help
Same as Nissan terrano
can someone help please i write mileage to the eeprom software says the mileage i want but when connected to car i get 990,xxx miles i have tried different dumps but none seem to work. also when i try to read with jprog no success and when i try dsp3 original also nothing can someone give me the solution please. heres the last dump i have.Attachment 659627
what number are you looking for???
your file has 121862km
I have the right number only problem is that when I read with carprog I have 121k miles but when I put cluster in car I have 903k miles. Could it be that I need to swap file? I don’t think so but someone with more experience than me can determine that.
Will that fix my issue of reading 903k miles on the car? And 121k when I connect carprog?
Swap and write. That will be fine
i have swapped with no good result file now says mileage not found also now the car reads 953k miles
it's just my suggestion ..
you should publish all the data, with original file.
read here ....
https://www.digital-kaos.co.uk/forum...php?f=174&a=32
__________________________________________________ ________
Also try to help others, not only the forum serves to ask for help.
WINNER THE LOSER
