Results 1 to 7 of 7
    Dec 2011
    Germany
    Default Reno Clio IAW 5NR2.C2 immo
    Pleace help in immo off or Clio 1.2 16v Engine Ecu IAW 5NR2.c2 eeprom 95160 pleace on good solucion immo off pleace attachet dump and Thanks
    sasy90's Avatar
    Italy
    use iud solution works fine...
    sasy90's Avatar
    Italy
    Italy
    Quote Originally Posted by Hazzard View Post
    Your dump immo off
    1-Change the eeprom 95160
    2-Connect Pin L4 with M4
    3-Cut the L4 Pin from the car wiring.
    4-Jumper the anti-starting relay, in the clio it is the black one in the center.
  5. The Following 3 Users Say Thank You to kobelco For This Useful Post:
    BusCan (6th January, 2020), Hazzard (16th October, 2019), t-ortman (9th July, 2021)
    Dec 2011
    Germany
    Thanks frend I try and raport
    Dec 2011
    Germany
    Thanks kobelco work perfect Thanks frend
    Italy
    Thanks for report
