Results 1 to 5 of 5
    Aug 2010
    Exclamation Hyundai I40 Smart key assyst immo Location 116RI-000348
    Hi m8
    need information.
    have a I40 with not Start in reason of a damage assyst Ecu 116RI-000348 ( pictures ) this item power up the Esl
    does any m8 know where here immo location is stored ? Can I swap it with a used one ?
    for all information a thnx in advance
    Sep 2016
    Post better pictures of pcb. For sure there are keys+pin stored.
    Aug 2010
    Here are new pics . I think immo data are in MCU 3M25J
    Have one m8 pinout for this
    I must change with a used second hand one
    Aug 2010
    For all with this problem ( Elv open Not work )
    solution
    if Elv not working check Fuse and power on steeringlock. If no power you habe a problem from key less go ECU. IT IS STORED ON PASSENGER SITE
    buy a second hand. Remove org MCU and place it in SECOND HAND
    ALL WORKS FINE
    give thnx if it help you
    Apr 2019
    Hi, I have that problem on Hyundai i40. ELV not working remotes not working!
    Assy-Smart key: 95480-3Z000 with motorola mask 3M25J
    You change this ecu and swap motorola?
    Brg,
    Pinocci
