Results 1 to 15 of 22
    Default Octavia 1.6 TDI PCR 2.1 DPF OFF
    Hello, guys, here is the dump from my friend's car. It is a Skoda Octavia 1.6 TDI CR.
    He already broke his DPF and emptied it.
    He asked me if I can remove DPF in the ecu, and I said I'll try, but I' ve never seen this ecu...
    Would someone help me please ?
    Here is the dump of the ECU (already unlocked)
    ECU part number : 03L906023AG
    Engine code is CAYC
    Thank you.
    Dec 2018
    Default DPF OFF
    try and report,
    pass pm.
    Jun 2018
    Bulgariq
    Quote Originally Posted by slklite View Post
    Engine code is CAYC
    Thank you.
    Pass-PM
    When you give a repot and thank you you will receive a password
    Quote Originally Posted by naskochipa View Post
    Pass-PM
    Hi, thanks.
    Is your file working 100% ?
    Thanks.
    Quote Originally Posted by diags View Post
    try and report,
    pass pm.
    Already got that one, made with ADS. But I don't if it's reliable...
    Team dz's Avatar
    Apr 2017
    ALGERIA
    You compare the program ADS file with WinOLS+ DAMOS got
    3 mistakes I pointed out by the red balloon
    Driven distance threshold for regeneration
    Minimum vehicle speed used for the low-load detection within the regeneration conditions for particulate filter
    Maximum differential pressure over the particulate filter to enable soot- mass calculation for particulate filter based on physical calculation method, differential pressure over particulate filter
    Filter factor for air mass flow setpoint increasing in idle
    filter factor for the moving mean value of the manifold pressure
    factor for low pass filter of diagnosis BPA_DIAG_EOL
    Factor to calculate the mass of ash inside the particulate filter based on the amount of fuel
    Manual correction factor for the soot- mass into particulate filter based on physical calculation method, differential pressure over the particulate filter
    Manual correction factor for the soot- mass into particulate filter based on soot-model
    Gradient limitation for the TQ_LIM_GB_PROT with error
    Maximum threshold for the soot-integrator of the soot-model to determine soot load of the particulate filter
    Minimum threshold for the soot-integrator of the soot-model to determine soot load of the particulate filter
    Maximum value for soot load of particulate filter related to the indicated torque
    Duration of the Disablement of the Diagnostic
    c_t_init_stuck_sig_egrv[0]
    Maximum regeneration time of the particulate filter used for the soot- message
    Maximal time treshold for complete particulate filter regeneration related to the iparticulate filter load
    Maximal time treshold for complete particulate filter regeneration related to the indicated torque setpoint
    Threshold for total injector runtime before 0 Km adaptation begins
    Minimum exhaust gas temperature threshold value 0 to enable soot- mass calculation for particulate filter based on physical calculation method, differential pressure over particulate filter
    Minimum exhaust gas temperature threshold value 1 to enable soot- mass calculation for particulate filter based on physical calculation method, differential pressure over particulate filter
    disabling egr-cooler depending on TEMP_EX (inj. state GES = 0) ERRORRRRRRRRRRRRRRRRRRRRRRRRRR
    disabling egr-cooler depending on TEMP_EX (inj. state GES = 1) ERRORRRRRRRRRRRRRRRRRRRRRRRRRR
    Minimum volume- flow through the turbocharger turbin to enable soot- mass calculation for particulate filter based on physical calculation method, differential pressure over particulate filter
    Volumetric flow upstream particulate filter threshold to enable diagnosis
    Maximum fuel consumption value since last regeneration in case of non-valid load state
    Minimum vehicle speed to enable soot- mass calculation for particulate filter based on physical calculation method, differential pressure over particulate filter
    In general it is a free program but it meets the purpose of some vehicles
    And not tired like WinOLS
    That's a personal ray
    It remains WinOLS programs
    In the foreground until now
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  7. The Following User Says Thank You to Team dz For This Useful Post:
    redash (19th October, 2019)
    Quote Originally Posted by Team dz View Post
    All right, thank you for the insight.
    So how should these 3 parameters be ? Remain untouched (original values) ? Are these modified only for a dpf off ?
    Thanks.
    Aug 2011
    Hi, you have 03L906023AG_9979 sw that is after diselgate action. Making dpf of on this sw is total disaster for engine. Make downgrade to sw lower than 9977 and take out plastic insert in MAF. Than I can make you corect dpf off. Your injector will start knocking in the morning in 10.000km with 9977 or higher sw ... if they do not allready.
  10. #9
    Quote Originally Posted by pipina View Post
    I hear you, how can I downgrade ?
    Thanks.
  11. #10
    Aug 2011
    with X17 from magic motorsport, or using .odx and tool that suport odx,sgo,... flashing, I use DiagRA D but there are other tools suporting too
  12. #11
    Too bad, I thought I could do it with kess...
  13. #12
    Team dz's Avatar
    Apr 2017
    ALGERIA
    You can do it with and KESS KATAG CLONE
    # Algerian #
  14. #13
    ivanmihov's Avatar
    Nov 2016
    Europe
    is soft with number ...9970 OK to do dpf off egr off
  15. #14
    Aug 2011
    Quote Originally Posted by ivanmihov View Post
    yes it is OK
  16. The Following User Says Thank You to pipina For This Useful Post:
    ivanmihov (19th October, 2019)
  17. #15
    tunelab's Avatar
    Feb 2019
    Can be done on your original file too with out any problem
    no need downgrade software
