If you will buy used module from same car, its will works without reflasing, else you will got sw not compatible fault fault and TCM will not working. If need clone or reflash new module pm me.
Dear Friends
Recently they brought to my workshop this Volvo S80 of the year 2011. In other workshops they tried to repair the automatic box over and over again, but they didn't find a solution. I currently see that the problem is the TCM. I'm not sure what the procedure is to change another used TCM. In any case it will be possible to change a used and complete automatic transmission to this vehicle?
What is the procedure to make this change?
Does it require any configuration with the original tool?
And what would be the procedure to install a new and virgin TCM to this Volvo S80?
thanks for your comments
Thank you very much for your comment friend. It means that a used TCM of another vehicle does not create any conflict with other modules for this Volvo S80, right ?.
Would you be so kind as to guide me step by step to put a new TCM into operation?
What tool should I have to install a new TCM? does it have to be done online from the Volvo server?
In case you have to clone what tool should I have?
Thank you for your help, friend
