    DK Veteran zoro1's Avatar
    Bulgaria,Sofia,Vidin
    Default audi a4 0281012113 hotstart fix
    Hi i need hotstart fix on this audi
    HW: 0281012113
    SW: 1037390981
    Large nations behave like gangsters ,and young as prostitutes !
    ivanmihov's Avatar
    Nov 2016
    Europe
    your file,pass in PM
  3. The Following User Says Thank You to ivanmihov For This Useful Post:
    zoro1 (18th October, 2019)
    Jun 2018
    Bulgariq
    Quote Originally Posted by zoro1 View Post
    HW: 0281012113
    SW: 1037390981
    Pass- PM
    when you give the repotation and thanks you will receive a password
  5. The Following User Says Thank You to naskochipa For This Useful Post:
    zoro1 (17th October, 2019)
  6. #4
    Thanks ,car is working with Ivan;s filr.Благодаря ,колега!
    File is read and write with Galleto v48 ,with my new too l-Kess 5xxx -dash on ,dash offf,dash on ,dash off -aaaaa f...!
    Hi again ,i whant to ask ,two files -car is working ,but there is differens in maps/chk too-but is normal/-is there some basik settings to add on "cold" map ,or it is like warm map/or close to warm map?Благодаря Ви за файловете ,има ли стандарт при увеличаването на горивото /копиране на "топлата" карта / или се добавят приблизителни стойноти?
  8. #6
    stanislav georgiev's Avatar
    Oct 2014
    България
    https://www.digital-kaos.co.uk/forum...n-Thread/page2 Hot-start fix You can try to do it yourself
  9. The Following User Says Thank You to stanislav georgiev For This Useful Post:
    zoro1 (19th October, 2019)
