Results 1 to 3 of 3
    Aug 2019
    Default Audi A4 B7 Switch Instrument Cluster
    Hi guys,
    I need some of your help.
    Lost all keys from 2008 Audi A4 B7.
    I have another instrument cluster with key and ECU from the same model. I can run the car with new ECU and new cluster (key fob is attached to sterring whell)
    My question, how to adopt new (used) cluster without loosing key?
    If i will adopt will i lose all key?
    Or maybe i should change somenthing else and use new cluster with new ECU?
    I have all pin codes and CS for both clusters and ECU
    Thank's for all support.
    Nov 2018
    Poland PL
    a new, clean transponder to the key, add to the instrument cluster and done. one note - e.g. VCDS you won't do it. you need dedicated diagnostic equipment for Immo and keys
    Aug 2019
    I lost my key, so i found another car with the same modules and also with keys.
    I changed locks and keys and i want to use original key, not aftermarket key.
