Results 1 to 8 of 8
    Aug 2019
    Default Audi A4 B7 Switch Instrument Cluster without loosing key
    Hi guys,
    I need some of your help.
    Lost all keys from 2008 Audi A4 B7.
    I have another instrument cluster with key and ECU from the same model. I can run the car with new ECU and new cluster (key fob is attached to sterring whell)
    My question, how to adopt new (used) cluster without loosing key?
    If i will adopt will i lose all key?
    Or maybe i should change somenthing else and use new cluster with new ECU?
    I have all pin codes and CS for both clusters and ECU
    Thank's for all support.
    rafal's Avatar
    UK - PL
    post more info....
    what engine , what ecu , what dash
    need help
    now my goal is to buy xp-005
    who will help?
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by rafal View Post
    post more info....
    ...what tolls You have...?
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
    Aug 2019
    Quote Originally Posted by baltazar3 View Post
    I have SVDI 2018 with abrites vag version 18 and 24
    Also i have Ross-Tech VCDS with Wag-Com
    Aug 2019
    I will check all numbers a little bit later and put all information here
    Dec 2018
    Minsk Belarus
    Quality svdi is able to do Immo date transfer from the dashboard to another RB8
    Aug 2019
    Quote Originally Posted by drrimz View Post
    Do you know how to transfer immo data? i try and is not working, maybe do you have some manual?
    Aug 2019
    post more info....
    Engine 2.0T
    2007 Audi A4 B7
    Backup Dashboards
    Original VIN: WAUAF78E48A046798
    Original ECU CS: 56C58C60AD8B
    Original Dash CS: A03BC3C74077
    Original PIN 49150
    Original ECU 8E1910115G
    Original Dash 8E0920951N
    Donor VIN: WAUAF78E38A169198
    Donor ECU CS: 6E49AE42DC93
    Donor Dash CS: 8F20A4311E41
    Donor PIN 41348
    Donor ECU: 8E1910115G
    Donor Dash 8E0920951N
    Backup of dashboard
    they are the same, i mean i have 2 same model of equipment
    But i have Key that work with new cluster(donor from another car) and with new ECU(donor), that allow me to start the car, but all rest modules on original car doesn't work, i mean ABS, ESP, ...
    I have error in communication
    I want to adapt old ECU with new Cluster but without loosing key from new dashboard. Is this possible or not?
    I'm afraid because i broke already one.
    I also have a question how to adopt rest of equipment? maybe just to use original car modules and use new ECU and new Dash?
    How about Radio also, if i will change ECU?
