Results 1 to 5 of 5
    Feb 2013
    Lithuania
    Default Opel Astra Multijat
    hello, i have opel astra 2009 years, 1.3CDTI. i need DPF off, i can read flash with kess on OBD? or need Ktag and bdm ?
    takiKolo's Avatar
    Sep 2015
    POLAND
    Read/write by kess via obd
    but better tell me HW SW or engine code then i waill tell u 100%
    May 2014
    LIthuania
    Quote Originally Posted by Edvardas View Post
    I use mpps v18 it can read flash, eeprom .mpc so you can work safely if its magneti marelli . kess also good enough . but if its edc 17 you must use ktag boot read . good luck . sekmes darbuose
    I think Tech 2 is the best option for this ecu
    i think it is not edc 17 ecu
