Here you go,regards
Here you go,regards
Do what you can with what you have .
Royro (18th October, 2019)
Thanks.
Is not MSS50, my ecu is MSS50.1
Hello.
immo is in left or right side??, can you send me photo of the correct chip??.
Thanks.
read partial via tool is enough. Send i will delete immo iun your file.
its easy going.
This pinout is ok??
88: K-Line
28: Ground
26, 54, 56, 60: Positive
sure can be read on bench. pinout look at internet.
for easiest way read partial.
kess read big endian... master and slave, also possible but need swap...
So if you gone this way you also can use your desolde readout
Pinout is ok.
This is my file read with kess
here you go.
If Lambda's file won't work, this should be it,
Royro (21st October, 2019)
Mine solutions is personally developed and tested by me .
He got solutions in slave and partial + advices , so if dont work isnt immo delete problem.
stueyBMW (13th September, 2020)
That could also be the problem, but in the V4.16 software the immo bit isn't active anymore, so a bypass in the immo soft routine is the solution.
No hard feelings....
I know. Partial arent recommended for him because he is on kess clone...
He got all he need. We will see his answer :9
