Hi guys, i have a BMW E90 2005 key code HA00008441 pull from the CAS, i try 0844 not work, i try HA00008441 decode to 0034, try HA0000844 then dolphin show two HU92R option (the two options have the same description), choose first one decode to 0042, second one 0030, at the end none of the above work Is it the machine issue or what number should i put in. Thanks
31334244
You should just pay up for code software...........
Quit being cheap if it pays the bills
lazymechanic (7th December, 2019), P&D (7th December, 2019)
i thought if you put the code in, the dolphin will give you the bitting? as i said, i tried 0844 (31334244) before it does not work. Thanks
Thats that code
It may have been rekeyed
Lishi. The door lock...
If you dont have lishi
Go buy it
If not take apart door lock and decode that way
dont forget about the key baby from handybaby guys
plenty of videos on that one out there
and then UHS just popped up with a new key cutting machine that im not sure where it came from
Recently purchased Dolphin to be able to do new KIA blade, as viper / 994 laser didn't have it in database, been using it as my main machine for a couple month now, struggled with a va2 2nd use, re-calibrated it and since then all keys ive cut have worked 1st time with finish machining turned on. HU66 VA2 HU100 HON66 ect. For the price it cost, its not that bad
<-- Please thank if i can help you
Silca KIA9 is available on the 994 (card 1418)
I've had my Dolphin for a couple of months now with no real problems, not bothered to try VA2, I just cut them manually.
Very easy to transport around with built in battery.
You get what you pay for, you can't compare it like for like, with a machine that costs 4-6 times more.
It doesn't cut to code, that's reflected in the price, so subscribe to Instacode, its only about £8.00 a month.
also , if any problem of the dolphin , pls add my skype to solve it quickly , my skype is in my profile
in xhorse app ,anyone is ok , and also you can add my skype . check my profile you can see my skype
hcip (20th December, 2019)
Anyone have same problem on curing Hu83?
I have tested all possible.
Even with "universal duplicate" menu.
The machine cut more than original and pierced also the key.
The key working in car but not perfect. And view is bad.
With Tapatalk
PocketHero (23rd April, 2020)
