Page 14 of 14 FirstFirst ... 491011121314
Results 196 to 198 of 198
Thread: Xhorse dolphin
  1. #196
    P&D's Avatar
    May 2010
    Quote Originally Posted by joker01 View Post
    okok... yesterday's work was done with a manual machine so ok....
    but with the dolphin if I have the key code I can use it to cut even if aluminum or I can't even cut and the cutter will break too???
    I don't seem to have plastic/aluminum cutting options.....
    Watch video watch from 45 seconds ....https://www.youtube.com/watch?v=vL5rH3jfM7I
  2. #197
    Jun 2013
    Yep - plastic / aluminium option at:
    0:47 into the video.
    Took a while myself.
    Before I even noticed this, in the daily life.
    Usually push buttons on the tab - next - continue.
    And not seeing all other options, available.
    Used a different machine, doing the plastic blades.
    Very happy when I found it.
    Saves a lot of time.
    https://youtu.be/vL5rH3jfM7I?t=47
  3. #198
    Jan 2017
    Netherlands
    Never seen the option (just blindly going on with the business I guess) but just put in blank metal first en when cutter starts pause it... Change for plastic, unpause an away it goes....
