Page 5 of 14 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 198
Thread: Xhorse dolphin
  1. #61
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by TERMINATOR1000 View Post
    Thanks , i need cheep machine just for cars keys , in AKL situation for EU cars only , small business ( 4 keys / days , with mechanical key cutting ... )
    X6/V8 is the solution OR SEC E9 is the only tool I must have ???
    An old post obviously ... but 4 lost keys a day wow u r busy do u sleep!
    Solidarity with Ukraine
  2. #62
    rob h's Avatar
    May 2011
    M4 clamp house hold keys.
    Customize key data, in the app, does not allow me to create key files.
    I can create keys, using the standard dolphin clamps.
    What i need in this app, is to add the M4 clamp.
    And the Condor mini, does it allow M4 custom files?
    With unlimited ammount of depths, or atleast 20.
  3. #63
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by rob h View Post
    few weeks ago I sent message to many people about Xhorse APP / Dolphin improvement
    Send message to Xhorse with your feedback
    you have complain form or in APP - feedback and suggestions) to send information to them
  4. The Following User Says Thank You to Maartinj For This Useful Post:
    fred77 (27th July, 2020)
  5. #64
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Quote Originally Posted by Maartinj View Post
    looks like they dont look
    many many bugs
  6. #65
    Jan 2017
    Netherlands
    Well, got mine in early this month and just got to using it a while ago. It was as a more portable machine and backup to the Sec-E9, especially since that one made a mess out of Benz keys. Cut a number of keys with the Dolphin just fine but last monday had to do 3 keys and 2 failed - Citroen C3 2011 VA2 blade, looks ok, but won't turn the lock. Also Benz key for a E220, after a little fiddling did turn in the the trunk lock but door is no go.
    Just redid all calibrations (inc. cutter and stepped back to 1.5 mm) , will do some extra testing tomorrow when visiting a car trader (lot's of test items around) but wasn't too happy this happened, you gotta be able to trust the cutting not to be an issue.
  7. The Following User Says Thank You to Matronix For This Useful Post:
    fred77 (29th July, 2020)
  8. #66
    Jan 2017
    Netherlands
    After some good advise now using HU64-2 option for Mercedes , also if car is before 2010 (which should be HU64). This works for me.
    The Sec does the HU83 and VA2 ok but would be nice of the dolpin would be doing those a bit better too. There was an update which should have fixed several issues (nice of Xhorse not to detail which issues those are) on cutting so maybe this was included as well.
  9. #67
    Maartinj's Avatar
    Nov 2010
    Poland
    if anyone need to contact Support / send feedback - here is quick view how to do that
  10. The Following User Says Thank You to Maartinj For This Useful Post:
    bobbel (11th August, 2020)
  11. #68
    Jan 2017
    Netherlands
    You can leave info about issues but they request wechat app to do online chat function for certain problems. Not sure I want wechat on my phone
  12. #69
    Newbie VictorVonDoom's Avatar
    Sep 2018
    Anybody know the proper size set screws for the bits , mine are wearing out. Seem to be out of stock everywhere I have looked and nothing in my shop fits it. Would happily buy 10 or more from Amazon or Ace hardware if I can get the correct size and thread.
  13. #70
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by VictorVonDoom View Post
    M4 fit perfect
  14. The Following User Says Thank You to Maartinj For This Useful Post:
    VictorVonDoom (16th September, 2020)
  15. #71
    Jan 2017
    USA ����
    Why are you wearing out the set screws..........
    I set a 2mm cutter in there and havnt changed it in like a year.......
    Changing the bit every key????
    You can just run with a 2mm allllll day looooong
    I Do 4-8 keys a day easy
    And it hasnt been changed in forever
    The bit size is a suggestion
    NOT A REQUIREMENT
    2mm bit does everything
    The thanks button is HERE looks like this --->>> THANKS
  16. The Following 2 Users Say Thank You to sleepyrz For This Useful Post:
    hitechservis (26th September, 2020), VictorVonDoom (16th September, 2020)
  17. #72
    Jan 2017
    USA ����
    Now the tracer i change every 4-6 months or. Basically whenever i screw up and break it off by leaving the shoulder stop on the jaw
  18. The Following User Says Thank You to sleepyrz For This Useful Post:
    electrobop (16th September, 2020)
  19. #73
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by sleepyrz View Post
    if you do dirty key, you can damage tracer for example evey mintue
  20. #74
    Sep 2018
    Thanks. What can I say other than habit probably created from using my 994 as my primary machine for so long.
    I will give the 2mm a try. Any key types in particular it has any trouble with?
    I will say that the 1.5mm cutter does do a better job on Honda keys. Used to have to wear down the sharp edges unless I wanted it stuck in the Ign
  21. #75
    Jan 2017
    USA ����
    Yes this will do it as well
    i always wire brush my keys before inserting
    Or if you forget to shave the outside of the aluminum keys to get off the oxide layer say on a jaguar key
    or a plastic key if you dont know how to work around them
    Must be smarter than the machine
    These things will do some silly shit if you let them
