Results 1 to 10 of 10
    Feb 2012
    Default Seat Exeo problem with immo
    Hello. At first I wanted to point out that it was my first dash of this type and that I simply failed with stupidity and rush. Unfortunately I have a problem. I have Seat exeo with damaged dash. The engine started correctly. I bought a second used dash and read the original through obd with the help of FVDI. Later, I put in the used one and uploaded the content via fvdi to the other one. This one showed deF and mileage below and engine not started. But the bigger problem arose when I returned to the old dash which showed LO 2-2 and the engine also does not start !!!. I only read the original one but did not program anything. Please help, because unfortunately I lacked knowledge. What should I do?
    Below the dump from the original 24c08 counter and 95640
    thanks for advance
    Feb 2012
    Maybe someone repair my LO 2-2 in my dump ? please
    rafal's Avatar
    UK - PL
    one more question: have u saved abs long coding?
    need help
    now my goal is to buy xp-005
    who will help?
  4. The Following User Says Thank You to rafal For This Useful Post:
    barth71 (17th October, 2019)
    Feb 2012
    Quote Originally Posted by rafal View Post
    Unfortunately not :-((
    I know my bad but I must repair this
    rafal's Avatar
    UK - PL
    with dash: change the immobilizer status to 6 and all come back to normal
    need help
    who will help?
  7. The Following User Says Thank You to rafal For This Useful Post:
  8. #6
    Feb 2012
    ok, I'll try this toomorow and report. I would ask you to how adopt a my new used dash ? I must have a new key for this or not?
    thank you very much
  9. #7
    rafal's Avatar
    UK - PL
    need help
    who will help?
  10. The Following User Says Thank You to rafal For This Useful Post:
    barth71 (18th October, 2019)
  11. #8
    Feb 2012
    ok thank you for your help. I must "fight" toomorow :-(
    regards
  12. #9
    Feb 2012
    Hi , thanks for your help . Everything works ok, old and new used dash. Immo state on 6 and dash works.
    Solution to adapt new dash from link also works.
  13. The Following User Says Thank You to barth71 For This Useful Post:
    rafal (18th October, 2019)
  14. #10
    rafal's Avatar
    UK - PL
    well done..............
    need help
    who will help?
