test and related
Hello everyone,
got an Aygo 1.0 12V 2009 1kr-fe who has ecu damage after beeing hit by lightning.
ECU was toast, so bought second hand one with keys.
fitted everything, and car wont start.
if we feed some brake cleaner in throttle valve it runs.
got fault code p2795 unmached key code. tryed several times to program keys. not working.
can anyone help me?
got dump from 95040 eprom
0261208702
89661-0H022
test and related
mr nox6 (22nd October, 2019)
When you say change ecu with keys what do you mean? Because the car is having immo so if the ecu got bad you just needed to swap eeprom and the car would start with its original key
bought used ecu with matching keys, so i assume. (or they riped me off?)
mouted ecu and tryed to start.
same issue.
also tryed the programming, 4 times now.
left car on ignition for 1 hour.
the keys has to go with the immo box and you sync with ecu in your case you bought ecu with keys witout immo box
so i think your best short is to try and to sync the ecu with original keys
mr nox6 (23rd October, 2019)
ok, good info.
will try asap
did you manage to solve your problem
keep in mind the sync process time has to be
exactly 30min not more
mr nox6 (9th November, 2019)
Hello
ok, update on this story.
bought a new immo box, tryed to pair it via diagbox.
computer says succes with pairing.
then tryed several keys to program with the 45 min with contact on.
still no luck.
what i noticed, when i put 12v onto the fuel pump and pump stays on, it will run for a sec.
then shuts off like a immo problem.
but when i look for data in immo box? it say the master key is in the ignition.
very strange
Update.
engine is running!!!
found several burnt wires in the main engine harnass.
just behind the airfilter box.
the 1 of the 2 immo cables that connects the immo box to the ecu was broken.
it will run if i put 12v onto the fuel pump.
so there will be an issue with a relais or broken wire, but will figure that out.
best regards
