Results 1 to 12 of 12
    Oct 2018
    Northern Ireland
    Default 1992 Renault Clio AKL
    Looking to do a key for this it’s an old Williams rally car. Know nothing about this year need some help please
    Is it ID33 ?
    Board type ?
    Blade type ?
    Can it be programmed OBD ?
    Any help would be much appreciated 👍🏻
    Thank you
    newone's Avatar
    Oct 2016
    immo from 1995-
  3. The Following 2 Users Say Thank You to newone For This Useful Post:
    Jimmy07 (18th October, 2019), Manta1600 (18th October, 2019)
    Mar 2018
    UK
    Quote Originally Posted by newone View Post
    immo from 1995-
    Is this for all cars or just for Renault
    I have Mercedes 1992 AKL on the doors handle has small windows that I think that are for IR remote but still cant open it to check for coil on ignition barrel
    RIMKACHIP's Avatar
    Feb 2012
    For Renault no immo in 1992
    Envoyé de mon iPhone en utilisant Tapatalk
    Oct 2018
    Northern Ireland
    IQ showing ID33
    scotland clydebank
    is a t5 transponder eeprom only on lost keys maybe renault ecu tool can do by obd .
  8. The Following User Says Thank You to godfathertre For This Useful Post:
  9. #7
    RIMKACHIP's Avatar
    Feb 2012
    Quote Originally Posted by godfathertre View Post
    1992 ? Not possible
    Obd plug on 1992 ??
  10. The Following User Says Thank You to RIMKACHIP For This Useful Post:
    Ecuprog31 (19th October, 2019)
  11. #8
    Apr 2016
    North Yorkshire
    I've done lost keys on a 1994 Clio, definately no transponder, think it was a NE72 blade.
  12. The Following User Says Thank You to Focus66 For This Useful Post:
    Jimmy07 (19th October, 2019)
  13. #9
    Oct 2018
    Northern Ireland
    Thanks Focus mixed reports about transponder hopefully there isn’t one. Not sure if being a Williams model if it would have better security than standard model
  14. #10
    newone's Avatar
    Oct 2016
    you will find no immo my friend...
  15. The Following User Says Thank You to newone For This Useful Post:
    Jimmy07 (20th October, 2019)
  16. #11
    Oct 2018
    Northern Ireland
    Thanks Newone I’ll pick lock cut new blade and hopefully it’ll start 🤗
  17. #12
    Mar 2009
    Whether it starts or not, it will not have a transponder. No cars had factory transponders before 1995. Some had aftermarket system before, some had remote immo system (just) before.
  18. The Following User Says Thank You to madaxe For This Useful Post:
