Results 1 to 7 of 7
    Dec 2018
    Default problem with toyota land cruiser 2016
    hello guys
    problem started when i tried to correct odo from 18000 to 58444
    its correctly done but stop counting means still 58444 after one month work
    but trip A & B counting good
    i readed the epprom today and found problem data in picture 1
    i tried to repair it and wrote new odo 123979
    then it started counting until 123984
    i thought it worked good
    i turned eng off
    and ater 5 minuts i run it again and oro returned to 123979 again
    wheres problem
    please help me to find this issus cuase its police vehicle and its urgently needed to back to worke immdetly
    sorry for bad english
    now the pictures attched and epprom backup and all info
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    I think you have problem about the dump but give it a try
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  3. The Following User Says Thank You to hcip For This Useful Post:
    jevara8451 (18th October, 2019)
    Dec 2018
    thnx sister but
    i need it 123979 or 124000
    and solve no couniting problem
    Dec 2018
    ok i will try
    hcip's Avatar
    Quote Originally Posted by jevara8451 View Post
    ok i will try
    if the problem still the same try to change with new dump as I can see your dump has an error
  7. The Following User Says Thank You to hcip For This Useful Post:
  8. #6
    Dec 2018
    thnx
    vehicle backed to work at this time
    they will bring it tomorro and will try both files and replay to you
    many thnx
  9. #7
    Dec 2018
    Quote Originally Posted by hcip View Post
    not working at all
    all meters not working no battery no coolant no rpm or speed
    now i downloaded the original dump that i backup befor ny edit (18000 km)
    its worked good
    now i need to edit it
