matik185 (18th October, 2019)
Waiting for Someone more.
I dont want to desolder it 3 Times and mount in car
Maybe Someone else ?
But thank you!
Wysłane z mojego SM-G973F przy użyciu Tapatalka
pin: 01364 km: 2003xx
Recuerde agradecer. pasar por la tarde
Bro sorry i gave you wrong code
01364 is correct login and mileage is 200362
thanks to those who gave correct code
i downloaded your file and selected a different file
Morning
Entering VVDS module 17 - instruments - security login - 01364 and it says pin is incorrect
Should I login to 25 - Immobiliser or 17- Instruments ?
Im using VCDS..
Im doing it First Time .. car is for my Personal use..
OK , pin is correct.. Ecu was blocked..
But..
In channel 01 it shows that is unrechable..
In measuring block in Adapted Keys it shows 0 :/
I cant add Key using adaptation / chanel 01..
I writed The file from you with immo off..engine started but immo Light is blinking..
Some ideas ?
go to someone in your area and will do for you this job by 15 min
need help
now my goal is to buy xp-005
who will help?
