LR discovery 2011 - "fat" proxy key
    sdnatlst's Avatar
    Aug 2011
    England
    319
    Default LR discovery 2011 - "fat" proxy key
    hi all,
    got a AKL on a 2011 disco 4 tomorrow.
    customer has said proxy key was FAT chunky type, as seen in attachment.
    I have 1 in stock so OK, but couple questions.
    1. Can we use newer slim type, found in 2012 models onwards? same TP and FCCID it seems
    2. Is programming just as easy, never done one of these chunky remotes, as the newer slim? I have used lonsdor which in the past done these in 30 seconds on 2012 models.
    thanks!
    Tools owned -
    May 2017
    Lebanon
    231
    Yes slim ones work .
    What tool do you use to orogram these ?
    Most tools risk corrupting kvm module. Ao be careful
    Sent from my LYA-L29 using Tapatalk
    If i was helpful DONT forget the THANKS and REP button
    Mar 2018
    UK
    457
    Quote Originally Posted by Moe1988 View Post
    KVM is corupting on models that have software update no matter what tool use
    fred77's Avatar
    Jun 2019
    217
    Less risk of buggering up but still chance on this year.
    AVDI changes the program flash so beware but done few this year ok
    sdnatlst's Avatar
    Aug 2011
    England
    319
    my tools tell me what SW is on KVM before asking to do program key,
    i know to look for FK72 which is update version, if i see this i would stop process and remove KVM.
    ghostrider72's Avatar
    Jul 2012
    UK
    199
    Coding slim key to the car with “fat” key works fine with AVDI. Just tried one today and all ok
