Here is your order.
could you read flash?
Post if it's cash: automatic or mechanical.
Did you already do ABS?
Here is your order.
WINNER THE LOSER
Felipevargas04 (19th October, 2019)
Hello my friend is mechanic ,,,,100% perfect thanks
Enviado desde mi SM-A605GN mediante Tapatalk
Hi friend, I have a question, is there a way to block my abs so I don't have to read it?
abs is easy, it has a 95320
it can be done from the dashboard without reading in abs ?
Smok licence RT0009 can do it dash+ ABS blocked by OBD.
Just be aware by patching or using blockers sometimes trip counter, average mpg don't work etc (not sure if cruise control is affected)
However I dont recomment to you any tool by obd2, the safest way is doing manually
I'm very sorry, I want to ask if you can modify dashboard without reading abs that you don't have to disassemble the abs if you can only through the dashboard
change mileage in dash, put dash back in the car, if mileage changes, you will not need to do abs, if mileage doesn't change you will have to do dash + abs
That is not possible. Only with a can blocker in dash. But it's not 100% safe
Friend thank you very much I already have more I have clearer everything. Have a great day
@jomberykaso
It is not possible with smok, the version of this car is Brazilian.
smok is only designed for Eu market.
That's why I asked @ Felipevargas04 if I could read FLASH, among other things.
inside the ABS there are 95640.
WINNER THE LOSER
