Results 1 to 7 of 7
    May 2010
    Default Doblo T-Jet only crank if sit Doblo Tjet with CNG. Arrived a little out of timing, s
    Arrived a little out of timing, so it turned over but never started.
    After correcting sync on timing, the first attempt is a crank no start.
    You have to leave the key on for half a minute then it will start and run well.
    If you repeat crank, it will start immediately.
    If you let it sit for 3 hours, again crank no start.
    Again, turn the key and wait half a minute then it will start and run well.
    With OEM diagnostic no fault stored.
    Compression is fine on all four cylinder.
    Spark plug are new.
    Bought a new OEM ECU but problem is not solved.
    With diagnostic temperature of air and water are ok.
    Have disconnected the CNG circuit but problem is not related with CNG.
    May 2018
    Ukraine
    Check voltage supply on board, when cranking. (example:loss voltage in groundwire).
    DiegoStud's Avatar
    Aug 2019
    I reckon lambda related-
    How old is the fuel if it's been running CNG mostly i assume?
    Do you have lambda readings while cranking?
    I know you say its not CNG but are you sure? By disconnected CNG do you mean electrically or gas supply removed?
    Leaking CNG valves will richen up the inlet manifold over time, when starting is attempted lambda sensor will correct and shut off fuel to prevent flooding. Give it 30 seconds for the lambda readings to drop and away you go.
  4. The Following User Says Thank You to DiegoStud For This Useful Post:
    alessioblaupunkt (22nd October, 2019)
    Meat-Head's Avatar
    Both above posts are awesome and agree with
    start with as its a fiat
    1) try push starting
    2) jumper cables from another car
    3) jumper cable from battery - to engine block
  6. #5
    May 2010
    @DiegoStud
    Fuel is new. According to Fiat documentation, the 2008-2014 CNG model
    ALWAYS start with petrol then it will switch to CNG.
    I will check lambda readings while cranking.
    CNG has been disconnected both electrical and gas supply.
    @MH
    Nice to test all of these, but if problem reappear every 3 hours
    of non use, I need 9 hours to do those test.
    Problem is customer want the van asap after spending a lot of money.
    Such a bastard fault, isn't it?
  7. #6
    Meat-Head's Avatar
    Reading again, sounds like immboliservl not release as voltage dropping
    deffo connect jumper cables
  8. #7
    May 2010
    SOLVED
    Old petrol.
    Fuel WAS NOT new.
    On 18th October I phoned to customer and it was angry for bill, time, van running as before, etc.
    The first thing I asked him was:
    <<It was low on petrol, have you done petrol?>>
    His answer:
    <<Yes, I've done petrol>>
    THAT'S FALSE:
    the van returned with nealy empty tank and when we took out the 3 liters
    inside, the van with new petrol started immediately, and three hours later,
    and again the morning after.
    Another (expensive) happy customer (FALSE and time waster).
    ______
  9. The Following 2 Users Say Thank You to alessioblaupunkt For This Useful Post:
    DiegoStud (23rd October, 2019), Meat-Head (22nd October, 2019)
