here with ALS.
Pop and bang is possible but got no time to do.
If anyone can do it free please for thanks. I would like pops, bangs and cracles map if possible switchable if not its fine. and also if possible launch control or hard cut with flames ?
Thank you
Audi A3 2.0TFSI BWA engine. 6speed MANUAL 2006 petrol
mods
r8 coils
oversized ram air induction
sports cats full exust with valves 3inch
The map i have is stage 2
here with ALS.
alextinou (19th October, 2019)
Thank you. Is this still my file with my stage 2 thanks ,!!
Sure, implemented in your file.
Mate watch to the end
What happend, turbo dead?
Started it back up. Starts fine however scared to test drive it . No smoke on idle. I have vaccume valve so maybe it closed and the pressure built and opened up making it do that
OK DO TURBO IS GONE.
If turbo blown you had to much pressure from cat or turbo damaged before. Self race 1:1 sind 30tkm in Edition 30 careless, stage 2+
There's no smoke or noises so I don't no if it's turbo. Maybe valve broke in the exhaust pipe
Sounds weird since first time you pedal to the floor mate.
Smoke like hell. Did you self do the file stage 2?
if run stable in idle it wont be valve.
Hello, it's all ok! Your work is AMAZING I have included video.
The problem I had was the sports CAT blew away throu the exhaust and got stuck in the back box. I went today and paid to have the box box removed! And the valves removed. Now it is VERY loud and flames on cut. Thank you very much! All I need now is pops and bangs crackles flames on switch 😂😂
Super but mine are bit harder , no cats... 3,5" from turbo to end.
Also possible via switch mate . But dont get the time for to do.
