Hi friends, dear msms0904 it would be necessary to thank the friends who help you by clicking on the thank you button, it will value the friends who help. it costs nothing but a press on the bottom left button "thank you"
Go to vagdashcom.de and download the edc16 calculator and do CS
msms0904 (23rd November, 2019)
Hi chli1976,
file link is dead on this website
Here the calculator
Thanks Chli1976
Is it the last version ? (corrected)
Hello everybody and thank you. So in the end i ordered BDM100 from china. It could read the file after 4 hours off messing with software.
Can somebody check the file please? I dont know yet if it red correctly.
Ok so i learned that the file cant be opened because it is compressed by bdm tool. I learned that it can be decompressed and data from each chip can be separated here are the files i red.
According to this on adress 41 and 42 of e2prom file can be found this:Attachment 669432
Am i looking at the correct place?
Here your eeprom file
msms0904 (25th November, 2019)
you can read/write eeprom with VCP on obd2
https://www.youtube.com/watch?v=bWzkT6VkYZo
regards
Hello can somebody help? I flashed it with BDm tool. Everithing OK now shows 0 flashes. But i still cant flash it with my MPPS. When trying to write it completes write in 1 second but does not flash anything.
Hi!
I would like to deactivate my egr from my audi a4 b7 1.9 tdi 116hp
I can not open this file with winols!
with titanium ecu no suitable driver is found and checksum can not be calculated either
Please help
read with kess v2 clone
I'll be doing an eeprom flash counter reset tomorrow when I'm opening the ecu and I'm tankful for finding this thread. My kess clone didn't seem to open the flash count screen, I selected the counter option but when I read the ecu with it, it just gave me this. I didn't know what to think of it then moved to read the file with my mpps. Mpps didn't manage to edit the eeprom when I wrote it back and now it's stuck in programming mode with more flash attempts than successful. I did try to write the file kess read with counter option enabled but again it didn't open any modify screen and it gave wake up error. It did write in recovery mode in counter option but nothing changed. What is this file, it's not like it had noread tag?
So I pulled the eeprom and edited the lines 41 to 48 to all 0s then checksummed the file. One week later the car stalled and refused to start. Put the original eeprom back with 7 failed and 3 succeded and it didn't even care, the engine started.
