113b600d092a0000881206ec901d0041b000
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76
77
VIN: WVWZZZ1KZ8W586784 Mileage: 88230km-54823miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 AL HW: 03C 906 032 C
Component: MED17.5.1 6458
Revision: 96H07--- Serial number: VWXBZ0H0749695
Coding: 0000075
Shop #: WSC 00102 935 176006
VCID: 67D6A69C566EF37706-8032
2 Faults Found:
001299 - Incorrect Immobilizer Key
P0513 - 000 -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 88191 km
Time Indication: 0
Date: 2000.00.00
Time: 11:14:05
Freeze Frame:
RPM: 1506 /min
Load: 11.8 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 44.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.065 V
008198 - Intake Manifold Flap; Bank 1
P2006 - 000 - Stuck Closed
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 88191 km
Time Indication: 0
Date: 2000.00.00
Time: 11:14:12
Freeze Frame:
RPM: 780 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 80.0°C
Temperature: 43.0°C
Voltage: 13.589 V
Readiness: 0010 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 050 M HW: 02E 927 770 AL
Component: GSG DSG AG6 541 1460
Revision: 54104 Serial number: 00001707190983
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 1C3CC970DFA8E0AF5B-8048
No fault code found.
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 43320 001 1048576
VCID: 77F6F6DCC6CE63F796-8022
6 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 195
Count: 44032
Count: 0
Count: 0
Count: 512
00778 - Steering Angle Sensor (G85)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 292
Count: 44032
Count: 0
Count: 0
Count: 512
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 279
Count: 44032
Count: 0
Count: 0
Count: 512
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 295
Count: 44032
Count: 0
Count: 0
Count: 512
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 270
Count: 44032
Count: 0
Count: 0
Count: 512
00150 - Plausibility Brake Booster System
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 12288
Count: 398
Count: 44288
Count: 0
Count: 0
Count: 512
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 76E8FBD801C41AFF8D-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008747657
Coding: E78F0F2700041500471400001400000000087F075C00010000 0000000000
Shop #: WSC 00000 785 00200
VCID: 336E02CC52364FD76A-8066
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 220708 021 0501
Coding: 00038805
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 200808 054 0402
Coding: 00217261
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 58 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BS0C+
Coding: 0013624
Shop #: WSC 01357 011 00200
VCID: 6CDCD9B04F88D02F6B-8038
Subsystem 1 - Serial number: 6332MSME3E624924F
Subsystem 2 - Serial number: 6342MSME3E66334FQ
Subsystem 3 - Serial number: 6352QSME76004200$
Subsystem 4 - Serial number: 6362QSME786D3D61Z
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0101
Coding: 0002122
Shop #: WSC 01392 785 00200
VCID: 78F4F5E00BD06C8F9F-802C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 874 A HW: 1K0 920 874 A
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007103
Shop #: WSC 13585 002 1048576
VCID: 2B5E1AAC8A06171722-807E
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 74519 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:18
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 220708F1000403
Coding: 6D817F0E4006020002
Shop #: WSC 27202 002 104857
VCID: 356A3CD45C4251E744-8060
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:15
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:15
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:10
Address 25: Immobilizer
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AL HW: 1K0 959 701 AL
Component: Tuer-SG 006 1203
Coding: 0000182
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 27202 002 1048576
2 Faults Found:
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 88220 km
Temperature: 32.0°C
Voltage: 12.40 V
Voltage: 12.20 V
014 - Defective
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D0484056008CF03E0FC00
VCID: 030E920C42163F57BA-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1K0 959 702 AL HW: 1K0 959 702 AL
Coding: 0000438
VCID: 79F2F0E430DA7587E0-802C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74ECC1D017B808EFB3-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1305
Coding: 0000144
Shop #: WSC 01392 785 1012552
VCID: 387435E04B50AC8F5F-806C
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
VCID: 397230E4705AB587A0-806C
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D5A14B4B41219273C-8078
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 HW: 1K8 035 730
Component: Telefon H06 3100
Revision: 00006000 Serial number: 20387920025966
Coding: 012100
Shop #: WSC 01316 785 00200
VCID: 66C8AB989164EA7F3D-8032
2 Faults Found:
03426 - Left Audio Channel
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Mileage: 88238 km
Time Indication: 0
Date: 2000.00.00
Time: 11:12:12
