Here is your file cleared.
Pass PM.
Must work 100%
Thanks and reputation+ are welcome.
Pass PM.
Must work 100%
Tecdiag (20th October, 2019)
Sorry. Reuploaded file with the same pass.
First file was wrong format.
i mean by not work..........on dashboard i have the warning airbag fault wich is displayed.
If you can not fix it, please leave it as it cameIF I HELPED YOU PUSH THANKS AND REP BUTTONS
Warning lamp can show that some of the system componts are not OK! (one or more airbag modules/seatbelts that exploded in an accident, for example)
That is why I ask you about diagnostics and errors (fault codes).
Maybe you car writes on the dashboard that crash data in ECU is stored? But I doubt very much.
Last edited by carlabevghenii; 20th October, 2019 at 07:30 PM. Reason: added detailed description of my point of view
Hi mate after diag i have this code error :C0200-00
Hello. Are you shure that you get this fault code from srs/ airbag ECU?
I havent found description of this fault code yet.
All that I found about this code refers to ABS system...
