Results 1 to 15 of 16
    Jun 2019
    Default Modus 1500dci My2004 FAULT Column Sterring LOCK CAN line
    For my modus 2004 1500Dci NoT WORK many Virgin FIle dowlnloaded Online.
    not recode with clip diag.
    Car won't start red led immo fix
    My problem is, car enter and return from renault now i have 1 EPS in car and 1 in box and never 0f this 2 unit have corret VIN.
    Renault say not possible but never of this 2 columns sterring is from this cars. Have 2 dump 24CL16 but not present ORI Dump eprom.
    1 EPS sterring columns not comunicate and distrub CAN Line, other work but whit different VIN.I can add for Virgineze unique dump 24C16 can work correctly in diag but different VIN and Key.
    My VIN is VF1P0E0532365125
    I have test file can start other modus, but not this car.
    I want try to verginize this file whit others modus whit different VIN and Key
    Many tnk's
    RIMKACHIP's Avatar
    Feb 2012
    Hello send référence of your eps (dae) 8200...... . your modus after 2005 you have dae calculator separate with 3 crews ?? Or if before 2005 your calculator is attached of your eps ?? Please send me pictures I can help you.
    Big problem if calculator separate and not origin of your eps because calculator is special for motor and sensor not compatible.
    Envoyé de mon iPhone en utilisant Tapatalk
    Jun 2019
    Many tnk's my friends for your time in sunday.
    I add photo from my EPS module.
    If you dont see correctly code in pics, i write it for you:
    Code IS : 8200433517
    This is module FULL Compatible whit my car. And is the module EPS you see and download attachment in firt post up.
    Best regards.
    Jun 2019
    This module in photo is MARK my2006 production, car is my2004
    Jun 2019
    I have buy file from ecufile Virgin whit some my Code, now try recode VIN whit Can CLip.
    DD4ALL and ELM FAULT, read other VIN but not write correct VIN and recognized ORI file from others cars came is VIRGIN....
    Big mistery
    Renault assicure NO Manipulated Eprom, and i don't have Silicon cover upper eprom
    I am disperate
    RIMKACHIP's Avatar
    Feb 2012
    Ok VIN is not immo it is just an information. Normally if your file is virgin when you put first time ignition on, eps recode automatically immo from uch. I think virgin file is not compatible with your calculator. For eps modus there is a lot of virgin files. Not one file for all models. Normally 2004 is 8200433517.
    Jun 2019
    FIle buy from ecufile not work not recognized EPS ecu AND not write VIN in eps
    Jun 2019
    Quote Originally Posted by RIMKACHIP View Post
    Can you verginize my File in first post, or have you a virgin file compatible whit my module??
    RIMKACHIP's Avatar
    Feb 2012
    Ok file you bought is for this models with calculator can be separate.
    RIMKACHIP's Avatar
    Feb 2012
    Yes I send you virgin file for your 8200433517. Just wait I am not in my home.
    Jun 2019
    Ok many tnk's i add file i have buy only change estension from .VIR to .BIN
    See file and i attend your comment, if is compatible or not but DAE code is egual of mine.
    I attend you reenter to home and virginized file i have found in EPS module whit different VIN.
    And plese write me procedure.
    Turn key on off and... recode eps whit VIN??
    RIMKACHIP's Avatar
    Feb 2012
    Ok but your file is not good. I will send you virgin file for your eps 8200433517.
  13. #13
    Jun 2019
    My file 24C16 PREUNTA or Possible whit different VIN you think is not good? and is not good for verginize?
  14. #14
    Jun 2019
    i am very tired, about 300km from my home.
    Can you help me please....
    MAny tnk's
  15. #15
    RIMKACHIP's Avatar
    Feb 2012
    Contact me by pm because tapatalk can not add file
  16. The Following User Says Thank You to RIMKACHIP For This Useful Post:
    Fabiuz (24th October, 2019)
