Results 1 to 15 of 15
    Oct 2019
    Default i need help with eeprom rcd 310
    hello friends i want to read eeprom rcd 310 i search on the pcb but i cannot find the right chip to read eeprom.
    on the pcb i see 2 chips wich i think one of them schould be the chip to read eeprom but i cannot identify which serie it is.
    one chip is 128wr st k941p
    the other one is k410 st z947
    the second chip is so small that i even cannot put a clip on it.
    chip 1 dos not have a dot to identify pin 1.
    who can help me.
    Nov 2013
    Macedonia
    For code you need to read eeprom ST95128 and NEC processor.
  3. The Following 4 Users Say Thank You to Zann For This Useful Post:
    cubica1 (21st October, 2019), irfa (22nd October, 2019), masterskay62 (21st October, 2019), shooting (21st October, 2019)
    Oct 2019
    is that chip number 1 or 2 on my picture ?
    Nov 2013
    Macedonia
    Number 1
    But you must read NEC too.
  6. #5
    Oct 2019
    Quote Originally Posted by Zann View Post
    Number 1
    i have ch341A i can do it with that ?
    i have also orderd ezp2019 but not received yet can i do it with this ?
    and can i read this one without desolder beqause i have also orderd hot air gun but also not received yet.
  7. #6
    Nov 2013
    Macedonia
    Quote Originally Posted by armo View Post
    Open the software and look if eeprom 95128 is supported by your programmer.
    It is recommended that you desolder eeprom from the board.
    For reading NEC processor you can use any USB-to-serial converter.
    Look here
    https://www.digital-kaos.co.uk/forum...highlight=v850
  8. The Following 4 Users Say Thank You to Zann For This Useful Post:
    cubica1 (22nd October, 2019), irfa (22nd October, 2019), shooting (22nd October, 2019), siti (22nd October, 2019)
  9. #7
    Jan 2012
    Europe
    Second option go local radio decoder
  10. The Following User Says Thank You to RadioChiP For This Useful Post:
    cheero (22nd October, 2019)
  11. #8
    Oct 2019
    I tried to read with clip but i only get ffffff. I have to wait until i receive hot air to desolder that chip.
  12. #9
    Oct 2019
    i have eeprom from 95128 who can calculate code for me?
  13. #10
    shooting's Avatar
    Feb 2010
    WALES
    You cannot get code from eeprom alone, post dump from NEC processor also
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  14. The Following 2 Users Say Thank You to shooting For This Useful Post:
    irfa (24th October, 2019), Zann (24th October, 2019)
  15. #11
    Oct 2019
    he is calculating without nec ?
  16. #12
    shooting's Avatar
    Feb 2010
    WALES
    Because that is DELPHI not BLAUPUNKT... not the same radio...
    wbr
  17. #13
    Oct 2019
    which hardware is the most easy to read the nec ?
    if i follow the instructions of the next topic then i have to add a reset button, 12v and so on, maybe there is al tool which make the work more easy ?
  18. #14
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    hy, i work with this ,calcuate alone algo ,no stres eazy to use
    http://www.codecard.eu/car-radio/rcd.../prod_665.html
  19. #15
    Oct 2019
    Look here
    for the programator V850 NEC i need 12k resistor trough 12v, can somebody give me a link from ebay which resistace i need to buy and how many for this job. thanks in advance
