Results 1 to 12 of 12
    Jan 2016
    Default Audi A4 2.0 TDI original file
    Hello, I need original flash from audi a4 b8, 2009 year.
    2.0 TDI, 88kw, CAGC engine code.
    VAG number; 03L906022
    May 2017
    EDC17CP14 or EDC17CP20?
    There is no flash data...only mpc inside.
    Jan 2016
    I know there is no flash, but I need ori file to see did someone make remap befoure....
    May 2017
    VR from CMD Server...
    If you want to compare need to read ecu also not only virtual read.
    Jan 2016
    Here it is read with MagicMotorsport, not virtual read... Can you compare is it remaped if you have ori file?
  6. The Following User Says Thank You to tomic19 For This Useful Post:
    enricogalati (16th December, 2021)
    Northern europe
    Flash with newer SGO then you are sure it's 100% stock.
    May 2017
    Correct way to do.
    ODIS and let it run.
  9. The Following User Says Thank You to Lambda1 For This Useful Post:
    tomic19 (23rd October, 2019)
  10. #8
    Jul 2019
    Everywhere
    Quote Originally Posted by tomic19 View Post
    Yes was remapped, but i dont like how was remapped.
    B. Regards
  11. The Following User Says Thank You to Johnwick88 For This Useful Post:
  12. #9
    Northern europe
    This is DAMN old software in this car Update to a newer version man.
  13. #10
    Jan 2016
    Quote Originally Posted by Johnwick88 View Post
    B. Regards
    Do you have ORI file to send me? We suspected on that becouse smoke from exhaust is huge....
    Quote Originally Posted by jaxone View Post
    I dont have ODIS to do that...
  14. #11
    Jul 2019
    Everywhere
    No, but you can found it in lot of site that sell original file from Ecu car.
  15. #12
    Northern europe
    Attached the pre diesel update version you can flash with ODIS / VAS / Vag Can Pro and I think Abrites can also flash FRF ? (not sure).
  16. The Following User Says Thank You to jaxone For This Useful Post:
