Results 1 to 10 of 10
    Default mjd9df fiat tipo dpf off correct
    Hi friend, i have delete dpf and egr and tune this car fiat tipo ecu mjd9df 1.3 mjet. But when car temperature is up 70°, white smoke continuos, dpd is in regeneration, but in memory, i not have dtc. Anyone can correct my file?
    Sep 2013
    what soot value?
    WinOLS5, custom files for ECU DCU
    i dont know. file is correct friend?
    Sep 2013
    can it be correct if regeneration begins?
  5. The Following User Says Thank You to pike For This Useful Post:
    kinketotua (23rd October, 2019)
    regeneration start at 70 degree, and don't stop
    Sep 2013
    Exclamation
    not right dpf off solution.
  8. The Following User Says Thank You to pike For This Useful Post:
  9. #7
    Hi, you have good solution for dpf off? Thanks
  10. #8
    anyone can help me?
  11. #9
    Sep 2013
    I can DPF off MJ9DF
  12. #10
    May 2017
    Turkey
    disconnect egt sensors and than check.
    Genuine 'WinOLS,MagPro2X17 Master, VagCom-Vcds, Vag Can Pro-Vcp'
    And 'Kess-Ktag' Red Pbc Ecu Clone User.
    Professional Car Remapper And Ecu Calibration Expert From TURKEY
