Results 1 to 15 of 16
    Jun 2018
    Bulgariq
    Default EDC17CP02 POPCORN LIMITER
    Hi I couldn't find any SVRL anyone can help
    rfernandes's Avatar
    Jun 2018
    portugal
    Check on this file...iam not at home...
    789F8 svrl...
    Jan 2018
    this is rail limiter not rev lımıter
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    you can do it in other maps, not only on rev limiter
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  5. The Following User Says Thank You to Ignasvw For This Useful Post:
    kinketotua (23rd October, 2019)
    Jun 2018
    Bulgariq
    Ok can anyone do it or do you mean no SVRL?
    rfernandes's Avatar
    Jun 2018
    portugal
    Quote Originally Posted by ecuremapper View Post
    Did not realize on what he write(popcorn)
    Apr 2016
    Quote Originally Posted by naskochipa View Post
    Here an example for you, go from there.
    Pass PM.
    Br.
    Michael
    Sep 2018
    Try address: 78918 factor 0,5. Should be it, 6000rpm is SVRL set on this. Find value 12000 after gear limiters.
  10. #9
    Jun 2018
    Bulgariq
    Quote Originally Posted by RSMtune View Post
    Did not work
  11. #10
    Member AKH84's Avatar
    Mar 2018
    France
    your single is at 58682 factor 0.5
    try and report
  12. #11
    Jun 2018
    Bulgariq
    Quote Originally Posted by AKH84 View Post
    try and report
    Did not work
  13. #12
    a500tut's Avatar
    Jun 2017
    Belarus
    Test this file.
    If I helped you, click thanks and reputation
  14. #13
    Jun 2018
    Bulgariq
    With the first file, the car stops at 4500 but doesn't care and two doesn't work
  15. #14
    Mar 2018
    France
    what address of single value?
  16. #15
    Jun 2018
    Bulgariq
    this file in which it stops at 4500 but no popcorn made it through the torrent and the one in which it tried SVRL Not working
