Results 1 to 10 of 10
    Aug 2015
    Default Hyundai Santafe 2007 2.2CRDi 114kW IQ/Torque limiter
    can someone help me with this file? In tunned file i requesting 450Nm of torque and 85mg of IQ, but diagnosis actual values i see that car giving only 70mg IQ and 370Nm.
    So where is the problem? I forgot some Torque or IQ limiter ?
    I attached both files.
    Thanks in advance
    some of lambda maps, torque limiter set to 415nm before limiters that you change, and this cars have two banks of maps so if you want make good stage read it with bdm, or you need use some tricks.
    Jun 2018
    Bulgariq
    Quote Originally Posted by shooperis View Post
    Thanks in advance
    TEST AND REPORT
    PASS-PM
    Aug 2015
    Quote Originally Posted by taraba123 View Post
    This car is manual gear so its enought OBD and i tried with BDM read/write (bank 2 maps) same situation. Lambda modification tried same.
    What kind of torque limiter is with 415nm? I gonna try it, but if limiter limiting to 415nm i get only 370nm?
    Aug 2015
    Quote Originally Posted by naskochipa View Post
    TEST AND REPORT
    PASS-PM
    Thanks, i will try and report.
    Aug 2015
    Same situation, i think somewhere is one more torque limiter.
    Jul 2019
    Everywhere
    I think need Damos
    Aug 2015
    Quote Originally Posted by Johnwick88 View Post
    I think need Damos
    Do you have it?
    Jul 2019
    Everywhere
    Do you have it?
    No I do not have this type of file.
    johak's Avatar
    try one more
  11. The Following User Says Thank You to johak For This Useful Post:
    shooperis (30th October, 2019)
