Results 1 to 9 of 9
    Junior Member popmpas's Avatar
    Feb 2018
    Default Audi A6 c6 3.0tdi problem
    hey.
    i got some problem with that A6.
    Its have a tunedfile but from other person i read that flash and make a DPF switch and egr off.
    when i reflash the ecu with dpfoff file then i got flashing pre glow warning light.
    dtc: not original software (or something else.)
    readed and reflashed with kess.
    checksum calculated with winols.
    Jul 2019
    have you tried just reprogramming the ecu sometimes you need to do that
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Quote Originally Posted by popmpas View Post
    hey.
    Disconnect all sensors from dpf.
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
    Feb 2018
    Quote Originally Posted by drewdom View Post
    all sensor disconnected but the problem is still alive because "not original software"
    but switch is ok car is not regenerating
    RBTuning's Avatar
    Oct 2019
    amsterdam
    the file isnt tuned, the egr isnt off and the dpf olso not deleted in the file you posted
    chrisimerk's Avatar
    Dec 2018
    England
    the file you read was shocking RBT tuning is right egr and dpf was not off and was a badly tuned file
    here i took the liberty to correcting it for you mate because im a nice guy
    try and report
    pass in pm
  7. The Following User Says Thank You to chrisimerk For This Useful Post:
    Jeanphil (29th November, 2019)
    Oct 2018
  10. The Following User Says Thank You to tothzsolt For This Useful Post:
    popmpas (11th November, 2019)
  11. #9
    Oct 2018
    ori flash from car dpf off chk ok
    test and report
    171.4KWKW Bosch 4F0907401C 4F0910402E
  12. The Following User Says Thank You to tothzsolt For This Useful Post:
    popmpas (12th November, 2019)
