Results 1 to 4 of 4
    Talleresmalaga's Avatar
    Nov 2017
    Espaņa
    Default synchronization error esw4.3 edc16c1 impossible
    Good night I try to synchronize bmw x5 ews4.3 with edc16c1, since all programs such as fvdi or diagnosis gives error can not synchronize, I can not find a tool to do it externally or manually deforms
    Do you know of any tool or form of manual synchronization?
    can someone synchronize this ecu with the ews4?
    If help is useful thanks+rep
    Jul 2016
    Ukraine
    Here is your new dump of the EWS with the transferred ISNfrom the motor (permanent) and cleared dynamic part (variable). Now you need to use a tool to synchronize the variable part, preferably inpa/GOOD LUCK/PASS IN PM.
  3. The Following User Says Thank You to urametz For This Useful Post:
    Talleresmalaga (24th October, 2019)
    Nov 2017
    Espaņa
    Quote Originally Posted by urametz View Post
    Thank you very much, sorry that I could not answer before, it's days to connect me, today I will approve, the car is 200km from my location and with so much trouble this week it was impossible to go, I already told you if it worked, how strange it would not allow the pairing with a virgin ews4.3,
    greetings
    Nov 2017
    Espaņa
    Good evening, we continue to have problems with esw4, let's change to ews3, upload your file, synchronize and the vehicle will start on the 1st lap
    Thank you so much
