Originally Posted by
rapidlocksmiths
vag group is one of worst to start with and one of most expensive to get good reliable coverage , vag is the one i get called to most after a cheap service has bricked it . no tool gives 100% coverage on vag so often multiple tools are needed .
vag tacho is very good and one of simplest for new starts to use but has gaps in coverage but is best kit on old beetle and TT
supervag has excellent coverage but also has large gaps especially on audi
mvp is dire on vag
chinese kit has some good coverage
xhorse vvdi2 is excellent
abrites is excellent
all of the above have their failures and weaknesses , having 3 or more and knowing how to use them helps maximise coverage .
train with hickleys and you wont be taught to use any of the above vag tools , you will be taught zedfull and smart pro on vag and only the menu driven functions , both use expensive tokens and both although having ok vag coverage , lacks the coverage of other units .
the easy part of the job is once learned , picking and decoding then making a key , plugging in and following the menu to code key , the fun starts when the computer says no , has no comms , cant read correct pin , then different kit is needed and different skills as it will be clocks out and work on these , trace and fix wiring faults , rematch units etc , none of which is taught by most training courses. broken and siezed locks , faulty ignitions etc , all regular jobs and situations not covered by most training courses .
good luck in your quest , it will frustrate you but its great fun learning
