Results 1 to 15 of 24
    dd1's Avatar
    Aug 2014
    Default MBZ S KLASS W220 EIS
    Hello to everyone, i have an eis out of mbz s klass w220, diagnosed at the dealer as eis bad, 215 5450008. part number. i have cloned the eis, but still the same the key wont turn. the car is not by me. if i post the files, both MCUs, can you guys look at them for any issue, meaning files are bad maybe?????
    dd1's Avatar
    Aug 2014
    sorry, forgot to include the files........they both have the 1D69J maskset. here they are
    Belarus
    see picture
  4. The Following User Says Thank You to Starling_vit For This Useful Post:
    brend (26th October, 2019)
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by Starling_vit View Post
    see picture
    can we repair the hash error?????
    Belarus
    write next key
  7. The Following User Says Thank You to Starling_vit For This Useful Post:
    dd1 (25th October, 2019)
  8. #6
    dd1's Avatar
    Aug 2014
    write next key
    I'm sorry I don't understand. You mean make a new key? Can you explain please ?
  9. #7
    brend's Avatar
    Oct 2015
    Same where
    If you not have second worked key ,progamm new one.
    For this you can use new (virgin) key or used which need erase before programming.
    Quote Originally Posted by dd1 View Post
  10. The Following 2 Users Say Thank You to brend For This Useful Post:
    dd1 (26th October, 2019), rafal (26th October, 2019)
  11. #8
    dd1's Avatar
    Aug 2014
    thank you, now the next question, on this eis which mcu holds the key data???? i am seeing this type of unit 1st time. the top or the bottom mcu?
  12. #9
    Belarus
    in both mcu write keys. data in mcu related
  13. #10
    dd1's Avatar
    Aug 2014
    sorry I am still not catching this, which mcu data should be used in order to make a key for this car? Is one mcu is enough? If so, then which one should I use? THANK YOU
  14. #11
    Belarus
    use data from any MCU
  15. The Following User Says Thank You to Starling_vit For This Useful Post:
    dd1 (28th October, 2019)
  16. #12
    dd1's Avatar
    Aug 2014
    hi everyone, i have made a new key, on a different slot and still the same thing. what should i do next????? the car is not with me.
    one note here, i programmed it in one mcu only, is this right, or i had to do both mcus???????
  17. #13
    Belarus
    what instrument did you make the key? mabye you write not correct type key? 011 021 031 041 051? key on moto or nec?
  18. #14
    dd1's Avatar
    Aug 2014
    used vvdi mb bga and 051
  19. #15
    Belarus
    mcu in key? moto? nec?
