Results 1 to 10 of 10
    Nov 2017
    Default FORD ecu sid206 eeprom write protection on. Cant write eeprom. Pl help
    Hi eweryone.
    I got damaged ford ecu sid206.
    Read flash and eeprom truogh bdm100 china clone.
    Try write back. Flash write no problem. Eeprom write protected.
    Failing to write. Any soliution for my problem. Thank you upfront.
    Nov 2017
    Anybody here?
    kiszka's Avatar
    Quote Originally Posted by remolyy View Post
    Anybody here?
    eeprom is on the other side of the board under the voltage converter
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  4. The Following User Says Thank You to kiszka For This Useful Post:
    remolyy (25th October, 2019)
    Nov 2017
    But is not one beside bdm pins marked 95320. I see on the other ones is other side ecu. But again why is writing protected. And how to deal with that? Thank you.
    dominik.m's Avatar
    Jun 2009
    POLAND
    He is not writing protected. Just bdm100 has a problem with some ecu.
    For example, Iveco edc16c39 also not all can write eeprom.
    Use Ktag or the programmer and a problem with your head
  7. The Following User Says Thank You to dominik.m For This Useful Post:
  8. #6
    Nov 2017
    How about Fgtech. Latest one v54 wuold do?
  9. #7
    dominik.m's Avatar
    Jun 2009
    POLAND
    With FGtech You can too.
  10. The Following User Says Thank You to dominik.m For This Useful Post:
  11. #8
    Nov 2017
    Hi again. Somebody know anyting about the sid206 bdm reading. Actualy about two pins need to be shortered to get it woring bdm. Actualy i found that on FGtech manual. It says need to be shortered other way isnot work. But again i done this but still bdm100 reads eeprom all 00000. And the writing back is writing protected. Wath is going on. Or just FGtech reads that way?
  12. #9
    dominik.m's Avatar
    Jun 2009
    POLAND
    If eeprom read 0000 alone, don't even try to write it down.
    It is better to desolder 95320 and convert into a second ecu.
  13. The Following 2 Users Say Thank You to dominik.m For This Useful Post:
    freelanceeeee (13th September, 2024), remolyy (28th October, 2019)
  14. #10
    Nov 2017
    Thank you dominik.
    Looks like only you reading posts.
    Somebody says that eeprom is in other side of pcb.
    But i opened ecu pcb. And is a ATA666 micro chip or someting. I think right eeprom is 95320 how you told.
    Thanks again. My FGtech should arive today. Try read with him. If not solder out and read in carprog. After just rewrite flash to donor ecu and solder in originall eeprom. Hope it works. Car need go out as soon is posible.
    Thans again.
