Hi eweryone.
I got damaged ford ecu sid206.
Read flash and eeprom truogh bdm100 china clone.
Try write back. Flash write no problem. Eeprom write protected.
Failing to write. Any soliution for my problem. Thank you upfront.
Hi eweryone.
Anybody here?
Reality of life :
1:Never argue with an idiot, he will drag you down to his level and beat you with experience
2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
3:Jealousy is a sign of inferiority
4:Everyone lies
How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
If you like to read garbage, don't slow down, just speed up
remolyy (25th October, 2019)
But is not one beside bdm pins marked 95320. I see on the other ones is other side ecu. But again why is writing protected. And how to deal with that? Thank you.
He is not writing protected. Just bdm100 has a problem with some ecu.
For example, Iveco edc16c39 also not all can write eeprom.
Use Ktag or the programmer and a problem with your head
How about Fgtech. Latest one v54 wuold do?
With FGtech You can too.
Hi again. Somebody know anyting about the sid206 bdm reading. Actualy about two pins need to be shortered to get it woring bdm. Actualy i found that on FGtech manual. It says need to be shortered other way isnot work. But again i done this but still bdm100 reads eeprom all 00000. And the writing back is writing protected. Wath is going on. Or just FGtech reads that way?
If eeprom read 0000 alone, don't even try to write it down.
It is better to desolder 95320 and convert into a second ecu.
freelanceeeee (13th September, 2024), remolyy (28th October, 2019)
Thank you dominik.
Looks like only you reading posts.
Somebody says that eeprom is in other side of pcb.
But i opened ecu pcb. And is a ATA666 micro chip or someting. I think right eeprom is 95320 how you told.
Thanks again. My FGtech should arive today. Try read with him. If not solder out and read in carprog. After just rewrite flash to donor ecu and solder in originall eeprom. Hope it works. Car need go out as soon is posible.
Thans again.
