Results 1 to 4 of 4
    Jan 2017
    Default A3 8P Cluster Swap without old cluster
    I have a A3 8p here and I am having some trouble with pairing new (used) cluster to the car.
    Old cluster is dead and I canīt read it. I first tried the VCDS procedure with the cluster pin and never have channel 50 available in the immo. Security code is accepted but channel 50 is never free...
    Next try was to code CS and Mac from the car to the cluster, by searching the forum I learned that its possible to get them from the Ecu dump (EDC16U1 with 95320 eeprom).
    From what I have looked the CS and Mac that I have from car is this ones:
    CS: B1 BD 35 DD 63 7A 6B
    MAC: 17 DB 93 92
    Pin: 59929
    The thing is that I sucessfuly transfered the CS, Mac and Pin to the new Cluster with original Carprog, and after that sucessfuly synchronized the original car key with the cluster, but canīt get ECU and Cluster to sync...
    Before transfering CS, Mac and Pin to the cluster the car didnīt have power windows and AC and had a big SAFE on odo, but now both are working, only having Safe on the partial odo...
    Also, I couldnīt transfer immo ID from car to new Cluster, keeps getting back to the original cluster ID, but I transfered Immo ID from new cluster to ECU dump and still blocked...
    What can I do more? I Attach the original ecu dump, one with Immo ID changed and the new cluster original dump and immo sector.
    If anyone can confirm my data I appreciate...
    Thanks in advance
    Jan 2017
    Well, after some tests and making immo off on ecu car is working with no immo error. Abs is getting error that Coding is incorrect, probably cluster is not compatible...
    rafal's Avatar
    UK - PL
    Quote Originally Posted by vitorponte View Post
    solution:
    https://www.digital-kaos.co.uk/forum...ng-for-members
    need help
    now my goal is to buy xp-005
    who will help?
  4. The Following User Says Thank You to rafal For This Useful Post:
    vitorponte (26th October, 2019)
    Jan 2017
    Quote Originally Posted by rafal View Post
    hello rafal. Thanks for your help, but i don't see long coding on this unit, just the old coding stile (7 digits) to setup brake caliper, engine, car model, suspention...
    Unit is a 1k0907379D esp front mk60 0102 (not the EC1)
