Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Dec 2009
    Yes, I did.
  2. #17
    Dec 2018
    Hello, the situation with our Peugeot continues.
    I was preparing a BSI from diesel (it only provided ACC). I downloaded the information from the original BSI (95128) and copied it to EEPROM of the new BSI. And …… it doesn't even give ACC anymore. From the original I easily got the VIN and code, but it seemed to me that the run was 0 kilometers. Is it damaged?
    Any ideas and suggestions?
    This is the original file.
  3. #18
    Dec 2018
    This is original.
  4. #19
    Mar 2013
    Random
    Go virgin from ecu take pin code and diagbox-it��
  5. #20
    systemlinux's Avatar
    Oct 2018
    CDK
    Touching a BSI is a deadly, very sensitive effect.
    Better IMMO OFF ECU or program key getting the pincode and virginize the file again.
    To configure the BSI you must have DIAGBOX (official PSA software).
  6. #21
    Dec 2018
    I thought to put the new BSI with his file, to put the ECU file without immo. The problem is that the ECM does not start with the new BSI at all. I watched IAW 6LPB give ACC through the CAN.
  7. #22
    Apr 2013
    Put ecu + bsi + key from donor vehicle if you have no clue ...
