Check power, ground and CAN. If it's all ok, change it as i did myself many times on those cars!
Greetings,
Greetings,
thanks,
you wouldn't have the power of the pinout. I think it's a bad module
Yes, please give me VIN or year and i'll try to find it.
By the way this one : 7 + ignition, 18 ground, 10 and 11 CAN.
BRUNOXXX (28th October, 2019)
this is VIN : VF1JZ0L0641732194
year 2009
thank you
Re,
You should find two connectors: little black / big yellow
Beware NOT to move or smash Airbag ECU when ignition is ON and ECU not fixed to car with his screws
Big yellow:
+ ignition ( 12V of course) on PIN 12
Little Black
Ground on PIN 75 (check it with test lamp 21W to 12V)
CAN H on PIN 19 (you should find with ignition on about 2,4V on DC voltmeter to the ground)
CAN L on PIN 18 (-------------------------------------2,2V-----------------------------)
Or have a look here with pictures, at the first page:
http://www.immo-tools.lt/site/files/...irBag_CONN.pdf
Greetings,
Hi, the power, gnd can are ok...If i send you files ori and reset can you look if are ok?
thank
Hi Bruno
Found the problem with the unit, I know too late, but maybe for another time !
https://www.digital-kaos.co.uk/forum...d-Know-default
