Results 1 to 7 of 7
    Aug 2013
    uk
    Default Iveco Daily 2007 Tacho DTC remove please edc16c39 - 0281012193
    hey guys,
    removed tacho from iveco daily, connected two yellow plugs as you do sorted cluster out but...
    could someone dtc off for me for tacho faults in edc16 and speed limit off.
    has no eml and rev above 3000 good - just has dtc.
    ecu information
    Bosch edc16c39 - 0281012193
    MPC562/REVD
    C107350W4LCCOV91P17.HEX
    E4 M1
    1037378086P_315V91
    flash M58BW016
    Read with fgtech via OBD
    fault codes attatched with flash.
    many thanks
    thayer201
    If i helped.... please dont forget to press the THANKS + REP buttons .
    prevozsa's Avatar
    Mar 2015
    Bosnia
    Default dtc off
    try and report
  3. The Following User Says Thank You to prevozsa For This Useful Post:
    thayer201 (30th October, 2019)
    Aug 2013
    uk
    Quote Originally Posted by prevozsa View Post
    try and report
    What did you do? Speed limit off and also dtc or just dtc?
    Aug 2013
    uk
    Quote Originally Posted by thayer201 View Post
    hey guys,
    ecu information
    MPC562/REVD
    E4 M1
    1037378086P_315V91
    flash M58BW016
    many thanks
    thayer201
    Can anyone else help.. need speed limit off aswell as dtc off..
    Above file is dtc only
    Many thanks
    Mar 2016
    Sweden
    Many thanks
    you have a limit mode 3000 RPM?
  7. The Following User Says Thank You to sonic 1989 For This Useful Post:
    thayer201 (1st November, 2019)
  8. #6
    Aug 2013
    uk
    Quote Originally Posted by sonic 1989 View Post
    yes i do can you help?
  9. #7
    Aug 2013
    uk
    hey guys,
    ecu information
    MPC562/REVD
    E4 M1
    1037378086P_315V91
    flash M58BW016
    many thanks
    thayer201
    Update.... stull having a bit of trouble wuth this one.
    I have speed working on cluster , but still no speed or engine speed fault in ECU - goes limp mode.
    Is there any other modifications that needs to be done when tacho off...
    Bcm any mod needed?
    Or can somehelp mod flash from ecu so no limp mode due to speed signal.
    Any help please guyy would be great.
    Br
    Thayer201
    SOLVED........
    Solved by DTC off and speed limit off
    Found speed limit and switched off in edc
    I think the problem came with speed sensor signal wiring issues after correcting that dtc off was still not enough.. switch limit off and no problems now.
    I do think the best way to do this is to mod bcm eeprom then configuration but thats info ive found here on dk.... i have not tryed it this way.
    Br
    Thayer201
