Results 1 to 7 of 7
    Apr 2016
    Default EDC17C74 DPF OFF
    Car was ok for a month with normal switch delete but went to the dealer recode the car keys and even if they didn't touch the file is not ok since then.
    No errors (beside key coding) but i can't reset pressure sensor and dpf so glow ligth is blinking, also bluetooth is not working after dealer visit......
    Tried to downgrade and upgrade de SW with FRF but still the same.
    Can anyone do me a DPF file with sensors off for testing?
    Thanks!!
    pike's Avatar
    Sep 2013
    Passat B8?
    johak's Avatar
    here you go
  4. The Following User Says Thank You to johak For This Useful Post:
    SpecZ (1st November, 2019)
    EUROPE
    same ecu here edc17c74 can someone remove dpf from this file?
    johak's Avatar
    your dpf off
  7. The Following User Says Thank You to johak For This Useful Post:
    kospoz (8th November, 2021)
  8. #6
    EUROPE
    Quote Originally Posted by johak View Post
    your dpf off
    Is possible also egr off to this file?
  9. #7
    Jan 2021
    Netherland
    Quote Originally Posted by kospoz View Post
    here file for you.
    pass via pm after rep+thx
    egr valve can be disconnected
    dpf temp and pressure sensors can be disconnected.
  10. The Following 2 Users Say Thank You to wjgud123 For This Useful Post:
    kospoz (12th August, 2023), sonic 1989 (8th August, 2023)
